AutoCAD Forum
AutoCAD 2007 Cannot Find Shared Canon LBP3300 Printer With Windows7
4 REPLIES 4
1248 Views, 4 Replies
Hello Friends,
Can someone help me with this problem :
I have windows 7 ( 32 bit) , i installed autocad 2007 on it and a Canon LBP 3300 printer installed on a Network PC with USB. Everything is working good but the problem is when i shared my computer with 2 printers on the network, i can see them with other softwares but when i plot with autocad 2007 i can't see them,  Is there anyone have a solution for me because i must keep working on autocad 2007.
Please provide me the correct solution .
4 REPLIES 4
pendean
OPTIONS command, PLOT tab, do you have the box checked for HIDE SYSTEM PRINTERS? uncheck it.
in reply to: pendean
Thanks for your reply but, I was alraedy done this.
I have manually added my network ploter/printer to AutpCAD 2007 and when I trying to print file then it shows it commands like preparing, plotting and plot completed but printer doesn't printed the file.
what shoul I do?
pendean
Your plotter's driver is not sending anything: AutoCAD will not fix that.
Can you plot to the other device? To DWF? TO PDF? For now you'll probably have to plot to something else like PDF or DWF then print to this new plotter from that file type viewer.
Thank you so much Mr. Dean Saadallah
Forma Design Contest
