Auto Update All Blocks in Palettes
Is there a way to automatically update all the blocks in Palettes when there is a change in the master drawings?
vinodkl
Is it that only the image is not updated? If yes then select one block in the palette and use shift to select all the blocks and then right click and select refresh image.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Hi @vinodkl , thanks for your respond.  The updating images just one of problems.  Another problem i'm having issue is changing the color in the main block doesn't automatically update in the Tool Palaettes.  For example when updated color to red in the main block, the palettes is using the old color Yellow.
