Auto Generate Array Dimensions
brockwesterman
Message 1 of 11
brockwesterman
Hi all! I find myself pulling dimensions on arrays very often. Most common is a path array from one specified point to each member. I will attach a screen grab to give some context. Is there an automated way to do this? It would save me a tremendous amount of time! ThanksScreenshot 2023-04-18 082448.jpg
Accepted solutions (3)
Replies (10)
Message 2 of 11
Kent1Cooper
BASELINE Dimensions should handle that for you [DIMBASELINE command -- read about it].
Kent Cooper, AIA
Message 3 of 11
brockwesterman
Oh that's great! how have I never known of this function!? How do I adjust the spacing on my dimensions? It is all running together when I pull BASELINE. Thanks again
Message 4 of 11
brockwesterman
Message 5 of 11
Kent1Cooper
@brockwesterman wrote:
... How do I adjust the spacing on my dimensions?....
In the Dimension Style editor:
Kent Cooper, AIA
Message 6 of 11
brockwesterman
Kent I sure appreciate it, a perfect solution!
Message 7 of 11
juanpablo8F4DP
Observer
Observer
HI! how do you solve this problem? . I have the same one
Message 8 of 11
j.palmeL29YX
Do you know the QDIM command?
Jürgen Palme
Message 9 of 11
Kent1Cooper
Explain what you don't understand about the approach in what they marked as accepted solutions.
[@j.palmeL29YX 's QDIM suggestion may work for you in certain circumstances.  But, for example, in the images in Messages 1 and 4, it may give you twice as many Dimensions as you want.]
Kent Cooper, AIA
Message 10 of 11
juanpablo8F4DP
Observer
Observer
No, but that command doesn't works for me. I need to take the distance between blocks, and when I tried to copy the "linear dimension" take the first point as a base and look like the image of the message
Message 11 of 11
pendean
Community Legend
Community Legend
...when I tried to copy the "linear dimension" ....
Copy?
....take the first point as a base and look like the image of the message
Do you just need to adjust the spacing as suggested below that message
https://forums.autodesk.com/t5/autocad-forum/auto-generate-array-dimensions/m-p/11904563#M1103772
