I want to slice two members thruogh the intersection plane. What is the easiest method to do this? Please help me.
Solved by nestly2. Go to Solution.
The first point you define for the slice plane is the point at the bottom where both of the members meet. This is the easy one to select.
For the second point I simply used a trick by shift+right clicking, choosing mid between two points; and then selecting the two corner points of the profiles. This will make your slice plane nicely symmetrical.
Sulari wrote:
Yes, It's working. But, how to define the intersection point correctly?
I typically use INTERFERE command to create a new (solid) object at the intersection, which can then be used to define the SLICE points.
Alternately, perhaps look into the TRIMSPLIT app in the Exchange Store for a more efficient approach
