Auto CAD 2018 - Batch Plot Issues
Help!
I have been using Auto CAD R-18 for a few months now and have had problems with my batch plot since I started using R-18, strange enough sometimes it will work fine but most of the time it will only plot one or two sheets no matter I send it directly to the plotter or to pdf Bluebeam or any other.
I have tried using default settings, although; I end up redoing my page set up with the same results every time.
I only have access to network plotters and when I use other workstations with earlier releases of AutoCAD, my batch plot works just fine.
Is there a patch that I might not be aware of or does anyone has had the same issue and found a cure.
Thank you in advance for your responses.
ennujozlagam
Try to install latest updates from Autodesk and see if helps. thanks
ennujozlagam
See updates below.
https://forums.autodesk.com/t5/autocad-forum/autocad-2018-1-1-is-available-now/td-p/7356562
