Anuncios
Auto bond option
Auto bond option
No aplicable
Hi. I'm currently struggling with auto bond option in Autocad 2020.
My drawings require moving many single parts, and due to that option, I'm wasting a lot of time. I would like to know if there is a way to turn off my option, so my lines would be seperate all the time.
Sorry for grammar misstakes, English is not my native.
Best regards.
0 Me gusta
Responder
Soluciones aceptadas (2)
1.027 Vistas
10 Respuestas
Respuestas (10)
imadHabash
Hi and Welcome to AutoCAD Forum,
what do you mean by Auto Bond option ? :cara_con_una_leve_sonrisa:  did your issue relate to PICKSTYLE (System Variable)  >> Click << . ?  or you have  group objects that you need to UNGROUP (Command) ?  or HPSEPARATE (System Variable)  >> Click << or it's a constraints issue >> Click <<
tell us more please or show us a screenshot for your issue ? :cara_con_una_leve_sonrisa:
Imad Habash
No aplicable
Screenshot_1.png When im drawing "lines" they automaticly connect. So when i try to move one of them, they move together.
0 Me gusta
imadHabash
try to use LINE command NOT Polyline .
Imad Habash
0 Me gusta
No aplicable
Command "line" is the only one im using currently. Thats why I'm surpsised by how it works.
0 Me gusta
Alfred.NESWADBA
Solución aceptada
In case you are already using LINE and not PLINE it might be the setting of system variable CONSTRAINTINFER (>>>details<<<), make sure it's set to 0.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
imadHabash
from above menu bar ( Draw tab ) if you start line command from there , any changes ?
Imad Habash
0 Me gusta
No aplicable
Here is a short video.
0 Me gusta
imadHabash
i think it's  constrain issue please type  DELCONSTRAINT and select your lines , any changes ?  check my post #2 .
Imad Habash
Alfred.NESWADBA
Solución aceptada
have you seen my suggestion about CONSTRAINTINFER?
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
Thank you so much. That was the command I needed.
You're both amazing. Thank you for everything :cara_con_una_leve_sonrisa:
