Audit command is not deleting the errors found
Message 1 of 15
On running audit command, it is detecting the errors but its not deleting it
Since we are using 3rd party software to open autocad, it is throwing error because of this
Kindly help in resolving, I get below message on running audit
Fix any errors detected? [Yes/No] <N>: y
Auditing Header
Auditing Tables
Auditing Entities Pass 1
Pass 1 6000 objects auditedAcDbSortentsTable(2DF0A)
Error for Entry (2DE97,2DE97) eDuplicateKey fixed
Error for Entry (2DE99,2DE99) eDuplicateKey fixed
Error for Entry (2DEA5,2DEA5) eDuplicateKey fixed
Error for Entry (2DEA7,2DEA7) eDuplicateKey fixed
Error for Entry (2DEBD,2DEBD) eDuplicateKey fixed
Error for Entry (2DED1,2DED1) eDuplicateKey fixed
Error for Entry (2DED9,2DED9) eDuplicateKey fixed
Error for Entry (2DEE5,2DEE5) eDuplicateKey fixed
Error for Entry (2DEE7,2DEE7) eDuplicateKey fixed
Error for Entry (2DEE9,2DEE9) eDuplicateKey fixed
Error for Entry (2DEEF,2DEEF) eDuplicateKey fixed
Error for Entry (2DEF9,2DEF9) eDuplicateKey fixed
Error for Entry (2DEFB,2DEFB) eDuplicateKey fixed
Error for Entry (2DEFD,2DEFD) eDuplicateKey fixed
Error for Entry (2DEFF,2DEFF) eDuplicateKey fixed
Error for Entry (2DFEF,2DFEF) eDuplicateKey fixed
Error for Entry (2E17C,2E17C) eDuplicateKey fixed
Pass 1 11400 objects audited
Auditing Entities Pass 2
Pass 2 6000 objects auditedAcDbSortentsTable(2DF0A)
Pass 2 11400 objects audited
Auditing Blocks
132 Blocks audited
Auditing AcDsRecords
Total errors found 34 fixed 34
Erased 0 objects
Thank You
Replies (14)
Message 2 of 15
cadffm
But the message say: fixED
So it was fix in this moment, thats my translation.
You can test it in this way:
Start Autocad by a well working desktoplink with parameter /safemode
Open your file by using command RECOVER, AUDIT, qsave.
Close and reopen the file, audit shouldnt find errors, richt?
Close your session and start in your current usual way (3.rd part software).
Open your new file and run audit again.
Errors detected or clean?
AND: Why do you ask here and not on the problem side (3.party),
whats the name of the software? Or try you program things yourself, it sounds so)
Sebastian
Message 3 of 15
hi,
Yes it shows as fixed, but wen i open the file through 3rd party software
It shows the same CAD handle, which is shown as fixed and throws a error
I am not a programmer and sorry i cannot give the 3rd party software information
But, If I delete all those objects mentioned manually. File will open without any errors
When i run audit it is not deleting these object, Kindly provide some guidance
Thank you
Message 4 of 15
S.Faris
Open the file using Command -RECOVER and see if it's gone.
SALMANUL FARIS
Message 5 of 15
Have tried that, after recovering if I run audit again
It showing same message
Message 6 of 15
S.Faris
Did you try running PURGE after AUDIT, close the file  and then -RECOVER?
SALMANUL FARIS
Message 7 of 15
cadffm
"When i run audit it is not deleting these object, "
Why should  cad delete the objects, the message said FIXED, not deleted.
The problem / error is pointing to the draworder, nothing more.
Sebastian
Message 8 of 15
Alfred.NESWADBA
first I would think that you are missing an AutoCAD update as your SortEnt table gets defects.
A second choice is to use copy and paste into a new drawing file.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
Message 9 of 15
hi
i have checked with latest version also
here the problem is we have hell lot of files like that
thank you
Message 10 of 15
S.Faris
if you can post a sample file here, maybe we can take a look and understand the issue.
SALMANUL FARIS
Message 11 of 15
Alfred.NESWADBA
Can you please start command _ABOUT with the latest version, I even don't know which version of AutoCAD you are referring to.
That is the second problem, not the first one. If we know how to solve the errors in one file (which is the primary issue) then we can discuss how to get the methods to repair one file applied to all files.
Have you tried the WBLOCK suggestion?
Any chance we get one of those files?
- alfred -
Alfred NESWADBA
Message 12 of 15
StevenMar
After going through many pages of notes from the forum, i *think* the problem is related to a block that was created in a vertical.  I was trying to open the drawing in AutoCAD and run AUDIT on it and it kept giving me the eDuplicateKey message and wouldn't fix the issue (although the message said it was fixed).
I was able to fix this problem by doing the following:
1) Open the drawing in the vertical this drawing was used in previously (I was using Civil 3D 2018)
2) Run AUDIT within that program (it will correct the errors in there) - save it.
3) I open it in AutoCAD 2019 and ran AUDIT again.  The message did not reappear.
It should be noted that I did have the Civil 3D 2019.3 Object Enabler installed.
Message 13 of 15
Alfred.NESWADBA
We even have not had a dwg-file here ...
- alfred -
Alfred NESWADBA
Message 14 of 15
cadffm
Hi Steven,
If you really talk about AcDbSortentsTable eDuplicateKey,
please post the link to this sample file, thank you.
Sebastian
Message 15 of 15
StevenMar
I am working with client data and do not have permissions to post the drawing.
It was my hope that detailing what I went through to fix the issue would allow others with the same error to try these steps to see if it works for them.
Sorry that I cannot post the files.
S
