Attributes Label
Attributes Label
shil143
Message 1 of 8
Attributes Label
shil143
Hi, I need help, if there is any lisp available out there that will create an attribute with an Arrow, TAG NAME, and Coordinates XYZ by clicking on a point. If possible the tag name will automatically increment. (Example 1st point is Tag Name A, next Tag name B, or 1st point is Tag no. 1, Tag no. 2 etc.) See screen shot .
Replies (7)
Message 2 of 8
Alfred.NESWADBA
I would create a dynamic block to handle the arror like a leader, and using _FIELD (>>>details<<<) to display the coordinates of the insertion point.
No LISP needed to do that, so this works with AutoCAD LT too.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 8
shil143
Please Explain Based on Attached Drawing and Excel File
Message 4 of 8
Alfred.NESWADBA
What does the XLS have to do with the original question "create an attribute with an Arrow, TAG NAME, and Coordinates XYZ by clicking on a point"?
- alfred -
Alfred NESWADBA
Message 5 of 8
Alfred.NESWADBA
please find a dwg attached which shows a block containing attributes, these attributes are using fields (the coordiate attributes, not the "ID" att), and wherever you insert the block (at least after REGEN) it shows the insertion coordinates automatically.
- alfred -
Alfred NESWADBA
Message 6 of 8
shil143
Thanks For Your Reply, But There is any Method key in Tag name  and Click in the marker to get Attribute Labels..........
Excel : after this Attribute table i want to update in Excel............
Message 7 of 8
Alfred.NESWADBA
I showed you a solution for your coordinate filling.
AutoCAD itself does not have a tool with automatically counting values (your TAG), you'll need a 3rd party tool then to first place my block (and so get the coordinates filled) and then run an index counter for your TAG attribute.
- alfred -
Alfred NESWADBA
Message 8 of 8
shil143
Thanks......................
I Used For TAG Numbering..................Below Link...............
https://apps.autodesk.com/ACD/en/Detail/Index?id=8051485828049059617&appLang=en&os=Win32_64&autostar...
