Anuncios
Attribute text not displaying
andrew.wheaton
andrew.wheaton
Good afternoon.
I am creating a block for a large setting out job and I cannot make the attribute text show.
I have created a block with attributed text and the text only shows when I edit the block.
Can anyone help me?
The block need to be called SOP.
0 Me gusta
Responder
Soluciones aceptadas (3)
580 Vistas
4 Respuestas
Respuestas (4)
andrew.wheaton
I have solved the attribute display issue.
I now cant seem to get the attribute to update in line with the attached sample of setting out information.
Can anyone help?
0 Me gusta
john.vellek
Solución aceptada
Hi @andrew.wheaton,
I redefined your block with a new attribute and it seems to be working properly. Please give it a try.
John Vellek
0 Me gusta
Alfred.NESWADBA
Solución aceptada
Can you describe what happens instead?
What does your command-line show when you start the script?
2 settings necessary to get that working:
  • ATTREQ = 1
  • ATTDIA = 0
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
john.vellek
Solución aceptada
Hi @andrew.wheaton,
Try setting ATTDIA=0 when you try to create the points.
John Vellek
0 Me gusta
