Attribute Sync Multiple Blocks
dbrblg
dbrblg
Is there a multi block ATTSYNC command?
I would have thought the ATTSYNC command would have let you put in * or select all but I cannot get that to work and the documentation for that command does not say anything about multiple blocks.
I've seen ATTSYNCALL but this appears third party paid for and I was looking for an in-built version.
Does AutoCAD have anything?
S.Faris
This worked for me:
Command: ATTSYNC
Enter an option [?/Name/Select] <Select>: N
Enter name of block to sync or [?]: *
ATTSYNC complete.
SALMANUL FARIS
dbrblg
I see now.
Seems when I tried, I was using the select option and not the name so the * did not work (I was trying * to select all and not all names)!!
Eduardo.Soethe
It doesn't work in this sequence, I have a lisp for that.
Eduardo Soethe Cursino
Civil Eng. | BIM Specialist
Soethe Cursino Consultoria | BIM for Infrastructure | LinkedIn
Autodesk Certified BIM Specialist: Road and Highways Solution
AutoCAD Civil 3D Certified Professional
__________________________________________________________________________
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma reposta e Kudos de gostou.
Autodesk Community
