Announcements
Attribute Editor Question
Hi All,
I use attributes within my Title block.  There is actually only 1 field that I need to individually update on each sheet.  The remainder of the attributes are linked through the drawing properties "Summary" and "Custom" tabs, so they are consistent throughout sheets and I dont need to enter the block editor each time.
Previously, when I want to change this field "Front Elevation" in the screen shot, when I would double click on it, the attribute editor would pop up and instantly allow me to change that field.  For some reason, lately it pops up it defaults me to the "Date" tag and I have to then scroll through the list to find "TitleLine1".  No matter which field I select, it always defaults to "Date" now.  Is there any way that I can have it select the actual tag instead of "Date"?
Any information you are able to provide would be greatly appreciated.
Mark
qnologi
Type "BATTMAN" then move up the one you want to edit first and hit apply.
qnologi
