Attribute coordinates to be converted into Z-coordinates
Hey guys,
I am experiencing a problem with some topografy models, which have the coordinates made as attributes and they are seen as a plano surface once opened in Autocad. Can I translate the attributes to Z-coordinates?
Thank you for your time and advices 🙂
ВeekeeCZ
You will need a LISP routine to do that. THIS  one seems to do just that.
HERE 's what to do with lisp
Alfred.NESWADBA
in case you have Civil 3D there exists the command _MOVEBLOCKSTOATTRIBELEV to move block-insertions to the elevation stored inside an attribute.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
ChicagoLooper
@Anonymous wrote:
<<Can I translate the attributes to Z-coordinates?>>
What do you want to do once you have the blocks at their proper elevation?
Chicagolooper
