Hi @Anonymous,
Perhaps I am misunderstanding but I understood that your third party application was able to insert the symbol and attribute you have on the grey lines.
The video you showed also looked like it was able to insert a block as well.
Your green lines do contain nodes (points) but they are not blocks. They are actually blocks with different names. Is it possible to have them inserted as only a single block? Then you can redfine with my block as I showed in my video. How are they being inserted? If you have a CSV file with the point data, there are ways in Excel to build a script that would insert all the point blocks to your coordinates.
Please give me some more information on your process.
I created a "library file" with my block with different names ....ptag1, ptag2, ptag3, etc.
I then redefined the blocks in your file using Design Center. I will email the file back to you for you to examine.
John Vellek
