I am using -ATTEDIT in script in order to change the drawing name in the titleblock.
I don´t know what the current value is, I want to change whatever it is to a new one.
What I get is new name appended to the old name.
Is there a way to replace the old value with a new one?
Command: -ATTEDIT
Edit attributes one at a time? [Yes/No] <Y>: n
Edit only attributes visible on screen? [Yes/No] <Y>: n
Enter block name specification <*>: MyBlock
Enter attribute tag specification <*>: MyTag
Enter attribute value specification <*>: I don´t know! I want to erase that! I hit Enter!
1 attributes selected.
Enter string to change: I don´t know! I want to erase that!
Enter new string: New Name
Result: New Name+Old Value.
What I want is just New name.
Solved by Ajilal.Vijayan. Go to Solution.
yes yes!
Thanks!
I found that at Lynn Allen´s Blog!
Much easier to use!
Why can´t ATTEDIT be as easy?
