Attach leader to text or mtext
Message 1 of 15
why is it that i can sometime attach a leader to text or mtext and other times i cant?
Replies (14)
Message 2 of 15
mwgrutter
What command are you using to try to connect the two?
QLATTACH is the express tool for this.
Can you post a drawing file that has the problem?
Michael Grutter
Cedar Engineering and Design Service
http://www.cedarengineering.com
2D Drafting, 3D Modeling, Legacy Conversion
Message 3 of 15
i am using that command. here is the file. some are attached and some arent. thanks
Message 4 of 15
mwgrutter
Sorry it took so long to reply.
The issue is elevation. The leaders will not attach to the MText objects if they are not on the same "Z" plane.
Michael Grutter
2D Drafting, 3D Modeling & Legacy Conversion
Message 5 of 15
Rickquin1965
Handy little command, thank you mwgrutter.
Message 6 of 15
Can you use this command with lite version? If so how exactly is this command used? I am trying to link some text to a leader, so when I move the leader it moves the text and visa versa is this the command I would use? Thanks sorry if this is the wrong thread I couldn't find anything on the forum as close to what I am asking as this one.
Message 7 of 15
chriscowgill7373
Hi Mike,  This is a really old post, however, the command is still not available in AutoCAD LT.  the command to attach the leader to the text is an express tool, which is not available for LT.
I'd recommend using MLEADER in the future, for existing leaders/text, there isnt much you can do in LT other than possibly recreated it as an MLEADER.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
Message 8 of 15
As I feared, thanks for the response on a dead thread much appreciated.
Message 9 of 15
Hey guys,
Stumbled on this thread wrestling with the same issue. I found this AutoLISP function that seems to do the trick.
https://autocadtips1.com/2012/03/12/add-leader-to-text-make-multileader/
Goodluck
-RT
Message 10 of 15
I tried this command, it says unknown command. I'm pretty sure it is
because I have the lite version.
Message 11 of 15
chriscowgill7373
@Anonymous
Yes, that would be correct, LT cannot run LISP programs.  Most of the Express tools were LISP programs, so they fall under the same umbrella.
Message 12 of 15
ebaum42M7L
Community Visitor
Community Visitor
Even with the full program, I am not able to run this command (mt2ml).  I still get the "unknown command" error.  I have the full version of AutoCAD - 2013.
Message 13 of 15
Ranjit_Singh
How did you load the lisp? Can you post a screenshot of command line history showing unknown command error?
Message 14 of 15
pendean
Community Legend
Community Legend
Walk us through exactly how you got the code off the site and into AutoCAD2013 in detail.
Message 15 of 15
ndixon1096
Observer
Observer
I don't know if anyone has answered your question yet regarding MT2ML.  It isn't a native command in AutoCAD.  To use follow the steps below:
1.  Download the MT2ML LISP routine from the web.
2. Use APPLOAD command to load the LISP routine.
3. Type the MT2ML command to start the LISP routine.
If you close AutoCAD you will need to use APPLOAD command to reload the routine.
I am stuck with the same original issue of having leaders that aren't associated with Mtext.  Unfortunately I don't have a current version of full blown AutoCAD.  Good luck.
