ASSOCIATIVE DIMENSIONS AND HATCH WITH PARAMETRIC FORM PROBLEM (AUTOCAD 2020)
No aplicable
Hy,
i have a file that i create with autocad 2013 with a parametric polyline. I associate dimensions and hatch with the polyline. With autocad 2013 i modify the polyline with dimension constrains and the hatch & normal dimension change with the polyline.
I open the same file in Autocad 2020 and it doesnt works. The normal dimensions & hatch result in the properties panel with associative but do not move with the polyline.
I try to create a new rectangular in autocad 2020 and i associate dimensions & hatch with it. If i modify the rectangular with a control point it modify dimensions and hatch. If i add a constraint dimension and i edit the number value, it modify the rectangle but the normal dimensions & the hatch dont move with the rectangle.
Any solutions?
0 Me gusta
Responder
347 Vistas
3 Respuestas
Respuestas (3)
qnologi
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/AutoC...
particularly...
Special Situations and Limitations
Associative dimensions support most types of geometric objects that you would expect to dimension. They do not support objects such as
Hatches
Images
Underlays
Multiline objects
2D solids
Note: Dimensions associated to model drawing views may lose their associativity if the drawing is opened and re-saved in a pre-2012 release of AutoCAD.
qnologi
0 Me gusta
No aplicable
The hatch is associate with the polyline. The polyline is associate with the constraint. Its not a direct association with the constraint and the hatch (that its impossible, as you linked).
The same file with Autocad 2013 is working fine. It modify hatch and normal dimensions. If i open it in Autocad 2020 or i create a new file (as the attachment file) id doesnt works.
Is it not possible fix the problem with autocad 2020?
0 Me gusta
No aplicable
I also noticed that if i use a control point of the polyline to modify it in a way that the constraint doesnt allow. The polyline doesnt modify and the hatch & normal dimensions refresh and move in the new position...
0 Me gusta
