Anuncios
Assistance with creating text blocks
jghughes
jghughes
Hi All,
Although I can "fudge" my way through with this issue, I'd like to learn how to do it properly.
I have an existing dwg title block that is missing text fields for the section for reference documents, which I now want to add. I've created a block for the text, created tags, synchronised the block, but still no success. I see that when I click on existing text blocks in the title block, they open in the Enhanced Attribute Editor, but this doesn't happen when I click on the new block I've created. I suspect I've done something wrong when setting up the attributes. I've read through a lot of blogs/sites today to learn how to do this, but I suspect that it's something too basic for people to devote time to. Any help would be greatly appreciated please.
0 Me gusta
Responder
Soluciones aceptadas (1)
397 Vistas
4 Respuestas
Respuestas (4)
Valentin-WSP
Solución aceptada
@jghughes ,
Sounds like you are doing everything correct; however, I get the impression you are trying to insert the Title Block already containing a block reference of an attribute definition - which will not work [like a block within a block].
Instead, create your Attribute Definition (ATTDEF Command) within the Title Block [NOT  a block reference], then insert your Title Block.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
0 Me gusta
paullimapa
share your title block so we can see what you've got
Paul Li
IT Specialist
@The Office
0 Me gusta
jghughes
Bechtel Level 3 - General. Non-Confidential Business Information.
It worked, thank you so much.
0 Me gusta
jghughes
