Anuncios
Assign a layer for a command lisp
krishravi2000
krishravi2000
Hi guys,
I am in requirement of a lisp "When I enter a command that command result has to be shown in that layer"
For example "if I gave the command XLINE and I have a layer named XLN the Xline should automatically be assignedto the XLN layer"
0 Me gusta
Responder
Soluciones aceptadas (1)
319 Vistas
1 Respuesta
Respuesta (1)
Kent1Cooper
Solución aceptada
For some things, that is already available [read about the DIMLAYER and HPLAYER System Variables].
For others, you can undefine and redefine the command name:
(command "_.undefine" "XLINE")
(defun C:XLINE ()
  (setvar 'clayer "YourPreferredXlineLayer")
  (command "_.XLINE")
You could also have it return the current Layer to what it was before, after you finish the XLINE command:
(defun C:XLINE (/ lay)
  (setq lay (getvar 'clayer))
  (command-s "_.XLINE")
  (setvar 'clayer lay)
If you sometimes have reason to draw XLINEs not on that Layer, type in the command with a period prefix:
.XLINE
to force use of the native command, not your redefinition.
Kent Cooper, AIA
