Artifacts in when moving objects.
I am experiencing artifacts when moving objects in model space and in the viewports. This mostly seen when zooming in and out. Producing "tracer tails". These artifacts hang around in model space. This is resolved with a regen, but I am having to do this constantly. The artifacts are getting in the way of the model. Any fixes??
imadHabash
maybe a screenshot will clarify more your issue to understand what artifacts means ?
Imad Habash
Alfred.NESWADBA
when you run command _REGEN, do these artifacts go away?
Can you please start command _GRAPHICSCONFIG, turn off hardware acceleration, do you then see the artifacts while moving objects too, or is the display then OK?
When you have the _GRAPHICSCONFIG dialog open, please create a screenshot from that and upload it.
Also please send us a screenshot of command _ABOUT so we can see which product and version you exactly have.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
