Artifacting Glitch on renders
No aplicable
Artifacting glitch on all renders no matter the settings, resolution, quality level.. nothing works.
32GB Ram
I7 8700K
AMD Radeon Vega Frontier Edition
Windows 10
AutoCAD 2020.1 Q70.0.0
0 Me gusta
Responder
Soluciones aceptadas (1)
618 Vistas
5 Respuestas
Respuestas (5)
Alfred.NESWADBA
in most cases this means you have multiple surfaces with different materials.
Make sure that you have just one surface/just one 3D-Solid at each location.
If you don't find the doubled objects then please upload the dwg-file.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
No aplicable
Here's that Drawing :cara_con_una_leve_sonrisa:
0 Me gusta
Alfred.NESWADBA
Solución aceptada
ok, in that case it's the material type "aluminium anodized", chose a different material like "metalic paint ==> glazed firebrick" ... just to see the difference.
Your objects are ok, no doubled surfaces, but take care with your coordinates, these are much too high:
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
THIS!!! Thank You! I kept the materials the same but I moved the test pipe to the base of the coordinates, It rendered perfectly!
0 Me gusta
Alfred.NESWADBA
great it worked!
Just one additional info: using render accuracy "low" or "draft" with a bit higher number of render passes also creates better images and faster (in most cases).
- alfred -
Alfred NESWADBA
0 Me gusta
