Arrays modifications doesn't show in the screen.
Good morning All,
I hope someone could help me with the following:
I have one file which since today where i want to change the number of columns in an dynamic array. The darkblue arrow's are shown on the right position, only the grahpical appearance stays as they where.
Than i tried the following steps already:
- checked if all layers where on, thawed, and unlocked.
- did do multiple audit and recoverys.
- did try same changes using AutoCAD 2015 instead of 2016.
noting of the above did work out.
Than i did try to make an new array but in this drawing no items are shown in the screen.
then i tried to use the edit source command, but after closing the array this item did disappear from the screen.
To check if this was applicable for the application or drawing, i did created a new file and did do array, and there it works fine. Also other another file of same project where i work on did work fine. So my conclusion is: there is something inside the drawing file which makes using array not showing but the existing stay's as they are.
Does anyone has seen this issue before? Is there an sollution othere than redraw the drawing?
Thanks in advance, Albert.
