ArrayClassic without Dialog Box
I don't like the Array Command in 2016. I want the much quicker version of years past. Using ArrayClassic is a big improvement but I want to make it even better by using the command prompt instead of the dialog box. Can someone help me get there? Basically I want the same Array Command I had in Acad 2010.
ambrosl
The -ARRAY command should allow you to use the older ARRAY command at the Command prompt.
Lee Ambrosius
Senior Principal Content Experience Designer
For additional help, check out the AutoCAD Developer Documentation
Alfred.NESWADBA
The answer for the old command without dialog is already done.
  • I just want to mention: any change you want to do after you created the array (distance, elements, objects used, ...) is not possible with the old array.
  • Path-Array is not possible with the old array
I'm not sure why the old one should be faster than the new one for creation, but I know that the new one is really faster if you want to modify any of the array parameters after the array was created 😉
Just my 2c, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Yes! That is exactly what I wanted. You did GOOD.  Thanks
Alfred..
I have never used Path-Array or had a reason to modify an array but I find the older version of array is faster for me.
Thanks for the comments though.
Gary Stone | Jacobs | Mechanical Design | Denver Colorado
Office 303-462-7451 | Cell 225-939-4794 | gary.stone@jacobs.com
GrantsPirate
You can use the official command,  ARRAYCLASSIC.  I love the new associative array but everyone has different needs so there are different ways to do the same thing.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
