Area measure Lisp
Area measure Lisp
kubastan89
Message 1 of 33
Area measure Lisp
kubastan89
I am looking for a lisp to measure hatch area in AutoCAD. I`ve found these two lisps:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/a-lisp-file-that-can-read-the-total-...
https://forums.autodesk.com/t5/autocad-land-desktop/how-do-calculate-the-area-of-a-hatch/td-p/157511...
but I am looking for a lisp that will insert the area value in each hatch like it does on this video:
https://www.youtube.com/watch?v=h-UoQ7SPjs0&t=269s
Of course I could buy the plugin from that video but I am looking for something that is free of charge.
I will be obliged for any help.
Replies (32)
Message 2 of 33
Alfred.NESWADBA
SCNR: are the drawings you create for free? Or will your efficiency get better when you use such a tool?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 33
imadHabash
you may find this link helpful. >> Click <<
Imad Habash
Message 4 of 33
kubastan89
Thanks for your link, but your lisp doesn`t put the area value on each hatch separately. It gives only one total value.
Message 5 of 33
Vinayv4v
Try this one.
Will only work for Polylines.
Cheers,
Vinay Vijayakumaran
Message 6 of 33
kubastan89
Is there a chance to change units from sq.ft. to sq.m ?
Message 7 of 33
Vinayv4v
Let me see.
Cheers,
Vinay Vijayakumaran
Message 8 of 33
kubastan89
The unit is correct but it gives the wrong value of the area.
Message 9 of 33
Vinayv4v
Try this one.
One is text version and other is field version.
Cheers,
Vinay Vijayakumaran
Message 10 of 33
kubastan89
Can you delete m? from the lisp. So the lisp give only the value without unit.
Message 11 of 33
Vinayv4v
Try the modified one.
Cheers,
Vinay Vijayakumaran
Message 12 of 33
kubastan89
Thanks a lot. Haven`t you thought about editing the lisp that it add the polyline number and create a table with the all areas ?
Message 13 of 33
Vinayv4v
Check this out from Lee Mac.
http://www.lee-mac.com/arealabel.html
Cheers,
Vinay Vijayakumaran
Message 14 of 33
kubastan89
This is exactly what I was looking for 🙂 Thanks again.
Message 15 of 33
i need esurvey cad programme and how to license it.
Message 16 of 33
I'm trying out this area lsp program. It loads fine
But what do you type to run this lisp ?
It does not say looking at the program with note pad.
Ron
Message 17 of 33
Vinayv4v
For the areabb Lisp you need to type areabb
And for Area Table Lisp you need to type AT.
Cheers,
Vinay Vijayakumaran
Message 18 of 33
Niether of those work for Lee Mac lisp program
Ron
Message 19 of 33
Vinayv4v
What message you get when typing AT in the command line after loading the Lee Mac Lisp.
Its perfectly working.
Can you attach a screencast or attach an image of your problem.
Cheers,
Vinay Vijayakumaran
Message 20 of 33
