Area measure Lisp
Area measure Lisp
kubastan89
Message 1 of 38
Area measure Lisp
kubastan89
I am looking for a lisp to measure hatch area in AutoCAD. I`ve found these two lisps:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/a-lisp-file-that-can-read-the-total-...
https://forums.autodesk.com/t5/autocad-land-desktop/how-do-calculate-the-area-of-a-hatch/td-p/157511...
but I am looking for a lisp that will insert the area value in each hatch like it does on this video:
https://www.youtube.com/watch?v=h-UoQ7SPjs0&t=269s
Of course I could buy the plugin from that video but I am looking for something that is free of charge.
I will be obliged for any help.
Replies (37)
Message 21 of 38
Got it working.
I did not select objects after the TABLE was placed
Ron
Message 22 of 38
please send me  Area measure Lisp free of cast
Message 23 of 38
Alfred.NESWADBA
@Anonymous
welcome @forums.autodesk.com!
>> please send me
Why should anyone send you anything when you can just click here to the (free) files to download it?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 24 of 38
hi sir how i can download this area lisp.
can you send me on this email.
tazeem224@gmail.com
Message 25 of 38
gotphish001
It's in the solution. Just click on it there and it takes you to where you can download it.
Nick DiPietro
Cad Manager/Monkey
Message 26 of 38
maramuresul
It's possible to get area in meter square ( I work with mm),  round off  1 or 2 digits (0,00)
and have the text a certain size.
One more thing would be, if I can have a text before generated area something like "A:"  , "area=" etc
Andrei C.
Message 27 of 38
Hello Vinay
how can I add text before area?
thank you
Message 28 of 38
Dear guy @Vinayv4v
Can you modify this lisp "A2 modify " area/1000000 and put m2 at end. Change font to
larger than .
Message 29 of 38
hi,
anyone can help me? thanks!
Message 30 of 38
Kent1Cooper
larger than ....
Try changing these parts:
  (cons 11 P_center)
  (cons 40 (getvar "textsize"))
  (cons 72 1)
  (cons 73 2)
  (cons 1 (strcat (rtos (vlax-curve-getArea e1))))
like this:
  (cons 11 P_center)
  (cons 40 YourDesiredHeight); <-- put in a number in drawing units
  (cons 72 1)
  (cons 73 2)
  (cons 1 (strcat (rtos (/ (vlax-curve-getArea e1) 1000000)) " m2"))
Kent Cooper, AIA
Message 31 of 38
Dear @Kent1Cooper
It is very clear,
Thank you very much,
Best regards
Message 32 of 38
daya94civil
Community Visitor
Community Visitor
how to enter the command in command line to use this lisp?
Message 33 of 38
Kent1Cooper
The name for an AutoLisp custom-defined command is always the part that immediately follows the C and colon in this part of the code:
(defun C:TheCommandName ..... [the C can be upper- or lower-case]
in the case of the routine at Message 11, A2.  If you're talking about the other accepted solution, the link tells you the command names to use.
Kent Cooper, AIA
Message 34 of 38
mr_hedayet_roni
Observer
Observer
I want to know how to use AutoCad's Arearon lisp to calculate Area in inches and I want to convert it to percentage. Can you please help me with that?
Message 35 of 38
mr_hedayet_roni
Observer
Observer
hi,
pls send me area measure lisp
Message 36 of 38
Kent1Cooper
@mr_hedayet_roni wrote:
.... I want to convert it to percentage. ....
Percentage of what?  An area is in square units, but a percentage is just a unitless number.
Also, post a link to where you're getting AREARON.lsp for the right version -- there are several Topics that have or link to or mention it.
Kent Cooper, AIA
Message 37 of 38
steve_MonkeyFlow
We have a tool for this on our free plugin CADflow - it will run on full AutoCAD 2020 onwards, and AutoCAD LT 2024 onwards.
Here's a vodeo that shows how the area tool runs:
CADflow – Adding Room Names and Areas– AutoCAD Blocks and Content Plugin from MonkeyFlow
You can download CADflow from the app store here:
CADflow V2 | AutoCAD | Autodesk App Store
Hope that helps.
www.monkeyflow.co.uk
Message 38 of 38
steve_MonkeyFlow
We have included several Area tools in our plugin CADflow which is in the Autodesk App Store, its free and will run on AutoCAD 2020+ and LT 2024+.
Just click on a hatch or polyline, then an attribute and it adds teh area as a field, so if the hatch or ployline changes, the area values updates.
Sorry can't post a link to it as it gets picked up as spam.
Howver, here's a video of it running:
