Anuncios
Area dialog box missing out
No aplicable
Dear,
        During my working in Autocad 2016 when I apply the area command and select the object of the desired area, the area appears for the very little time and suddenly missing out. Regarding solution, I apply again the area command to check the area.
0 Me gusta
Responder
Soluciones aceptadas (1)
2.644 Vistas
8 Respuestas
Respuestas (8)
cadffm
Which Program? Area command of AutoCAD never had a dialog window.
Sebastian
0 Me gusta
imadHabash
>>  the area appears for the very little time and suddenly missing out. <<
This is unusual AutoCAD  area command. please confirm that you're NOT using a lisp command or outsource plugins .
Command: AREA
Specify first corner point or [Object/Add area/Subtract area] <Object>: o
Select objects:
Area = 25.0000, Perimeter = 20.0000
Imad Habash
0 Me gusta
cadffm
Or you´re working with dynamic input, and the Information disappearing from the Cursor?
I don't no why, but you can read the information from Textwindow[F2] too.
As Workaround, display last "area" value from system varaible AREA into the statusbar:
Command: (setvar "MODEMACRO" "LastAreaValue: $(rtos,$(getvar,area),2,15)")
Sebastian
0 Me gusta
Michiel.Valcke
why not open the _PROPERTIES window and read your values from there?
0 Me gusta
No aplicable
Dear,
        could you please tell me whether this result can get in Sft instead of a square inch.
Kindly find the attached file.
0 Me gusta
cadffm
Solución aceptada
I'm not so familiar with imperial units, but divide by 144 sounds good, right?
Modemacro
LastAreaValue: $(/,$(getvar,area),144.0) sq.ft
AutoCAD DIESEL Reference
Sebastian
No aplicable
Dear,
         One little issue facing is that Is it this code is applied for whole AutoCAD setting.
because when I close AutoCAD and reopen it this code does not work.
0 Me gusta
cadffm
Modemacro value is temporary, yes
http://help.autodesk.com/view/ACD/2018/ENU/?guid=GUID-3637B188-6520-4BCB-B40F-1E0428AE34AD
Look for a way to set it by Autocad or Document Start
Search Tags for you:
Appload (Startup)
acad.lsp
acaddoc.lsp
commandline switch /s
Sebastian
0 Me gusta
