Area calculation
Area calculation
Area calculation
Which is the best way to calculate separately the up side of the drawing?
Thanks in advance
Alfred.NESWADBA
Create a hatch, then select the hatch and look to the property window ==> it shows the area of the hatch.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Slawomir_
As an alternative approach you can draw line between arc end points. Join arc and line using PEDIT command. Finally use AREA > Object command.
Try typing in "FEILD" in the command line.
If you search this forum under "Auto Enter Areas" there are pointers on how to use it.
parkr4st
If it is an arc, select it, look at properties.
Dave
imadHabash
Hi and welcome to AutoDesk Forum,
additional way is to make boundary polyline by BPOLY command, then by Arae command or Ctrl+1 (Proprieties dialog ) you will know the area. see below screencast on how to deal with and also see also at the end how to fix the arc because i doubt that it's correct.
LINK to screencast... >> Click <<
Good Luck .. 🙂
Imad Habash
Kent1Cooper
Another option [as if you don't have enough already], if that's an Arc on top and a Line across the middle:  REGION, select the Arc and Line, select the resulting Region and look at its Area in the Properties palette.
Kent Cooper, AIA
