ArcGIS for AutoCAD geolocation troubleshoot
kascUGWU5
Observer Observer
Message 1 of 11
kascUGWU5
Observer
Observer
When I turn on the ESRI map in an xref drawing, the map and the drawing line up well.  But when I open the drawing which the xref is inserted into, the map does not line up with drawing.  How can I resolve this?
Replies (10)
Message 2 of 11
pendean
Community Legend
Community Legend
ARCGIS support is over there https://support.esri.com/en
Their user forums (like here, but for that add-on) is over here https://community.esri.com/
Message 3 of 11
Pointdump
Hi Kyle,
Welcome to the Autodesk Forums.
Are you using Vanilla AutoCAD or do you have Map 3D or Civil 3D?
Screen shots showing the misalignment would be helpful. Posting your drawings would be even better.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 4 of 11
kascUGWU5
Observer
Observer
Thank you for the reply.  I'm using vanilla (lol) autocad. Please see attached files
Message 5 of 11
cadffm
You forgot to share an Screenshot or similar to show the issue.
I can not see what your trouble is.
Please share a markup or whatever we can be sure that we talk about the same.
(I would need to know what you expect and what you see instead)
Sebastian
Message 6 of 11
cadffm
if you are talking about the PDF: You forgot to share this file -
Sebastian
Message 7 of 11
kascUGWU5
Observer
Observer
Here are two images of my drawings.  The basemap shows the properly aligned survey on the esri map, and the second shows the construction drawing with the xref drawing, misaligned, floating in the ocean
Message 8 of 11
Pointdump
Kyle,
Thanks for posting your drawings.
basemapTEST.dwg is in US Survey Foot units and JamesWilliamsCONCEPT.dwg is in Inch units. That is most likely the biggest source of trouble. External References Manager shows a PDF, vmap-1.pdf that you did not attach.
basemapTEST.dwg, after setting the UCS back to World, is correctly georeferenced, and the linework agrees with Bing Live Maps. (I don't have ArcGIS for AutoCAD, so can't test there)
Dave
Dave Stoll
Las Vegas, Nevada
Message 9 of 11
kascUGWU5
Observer
Observer
Thank you for your help.  I have set the units to US survey foot for both drawings. Now it is in the correct location, but the drawing is out of scale of the esri map.  any thoughts on this?
Message 10 of 11
pendean
Community Legend
Community Legend
@kascUGWU5  Like 12x out of scale? or 25.4x? or some other combo of that?
Message 11 of 11
kascUGWU5
Observer
Observer
My drawing is at the correct scale (properties of line work showing lengths of lines as I intended) but the drawing is much larger than the space it should occupy on the esri map, see image
