Anuncios
Arc drawn looks not attached to a line's end point
No aplicable
Hi, I am currently using Autocad 2019. When I draw a 3 points arc, the arc seems not attached to the starting & last point of the arc. This only happen when I am in 2 viewport mode & the arc look normal in 1 view port mode. Pls help. :cara_con_una_leve_sonrisa:
0 Me gusta
Responder
Soluciones aceptadas (1)
1.371 Vistas
4 Respuestas
Respuestas (4)
j.palmeL29YX
Are you sure you are in a Plan View?
Jürgen Palme
0 Me gusta
Alfred.NESWADBA
what happens when you turn off hardware acceleration (command _GRAPHICSCONFIG)?
Also please show us a screenshot
  • of dialog/command _GRAPHICSCONFIG (so we see your graphic card driver)
  • of dialog/command _ABOUT (so we see your product and version)
  • if possible also let us test with your drawing on our systems.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
0 Me gusta
imadHabash
Solución aceptada
if you copy the same area of your drawing to a new and empty drawing , any changes or what ? if NOT .. please attache here your clouded area for testing ?
Imad Habash
No aplicable
I copied the elevation to an empty drawing & the arc looks normal. Thank you for your help.
0 Me gusta
