How do you take off the little arc icon from the numerical value in the arc dimension. I just want the number without the icon...?
Solved by j.palmeL29YX. Go to Solution.
DIMARCSYM -> 2
Jürgen Palme
DIMARCSYM -> 2
Jürgen Palme
You don't need to know the System Variable name involved -- you can set it via the Dimension Style / Modify dialog box:
