Arabic letters are splitting AutoCAD to PDF
binuntachari
binuntachari
cheryl.buck
Autodesk Support
Autodesk Support
Hi @binuntachari,
Thank you for posting your question and for providing a video of your steps and the results.
It looks like the plot looks correct in the preview window. What you see in the preview window is what AutoCAD is exporting. The translation to PDF is then handled by the print or plot driver you choose, in this case Adobe PDF.
It is possible that the Adobe PDF driver does not have access to the same font you are using in AutoCAD and it is substituting with the next closest font is has access to or one with the same name but different content. Can you check the text in the PDF to verify the font that is being used, versus the one used in AutoCAD?
If you try a different PDF driver, like the AutoCAD PDF (General Documentation), do you get the same results?
Please let me know if this helps.
If a post was helpful, Likes are always welcome.
Please click the Accept Solution button for any posts that resolve the issue or answer your question.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
