apply formulas between Attribute tags
Automohan
Automohan
Please help?
ACT. SURVEY (TAG) - DRONE (TAG)  = DIFFERENT (TAG)
I need to put formula
"Save Energy"
Did you find this reply helpful? If so please use the Accept as Solution
0 Me gusta
Responder
Soluciones aceptadas (1)
282 Vistas
1 Respuesta
Respuesta (1)
cadffm
Solución aceptada
Then do it?
Paste in a field, type FORMULAR...
There in the editor area, you paste in a field, type Object <selec you blockreference>, choose the attribute,
  back in formular field dialog type in -
then paste in a field, type Object <selec you blockreference>, choose the other attribute.
Your formular field (in the formular field editor area) should looks like
{field - link to attribute1} - {field - link to attribute2}
BUT you get no + sign, only the - sign for negative values.
AND you have to do it before you place the 2-999 blockreference (by copy the first blockreference).
Or you need a tool to do this.
Sebastian
0 Me gusta
