Anuncios
Application does not support just-in-time (JIT) debugging
No aplicable
Can you help me please ? I dont know what to do. I believe when i download new upgrade , this happened.
debugging. See the end of this message for details.
************** Exception Text **************
System.Windows.Markup.XamlParseException: Set connectionId threw an exception. ---> System.InvalidCastException: Unable to cast object of type 'System.Windows.Controls.Grid' to type 'System.Windows.Controls.ContextMenu'.
at Autodesk.AutoCAD.UserControls.DocumentSwitchControl.System.Windows.Markup.IComponentConnector.Connect(Int32 connectionId, Object target)
at MS.Internal.Xaml.Runtime.ClrObjectRuntime.SetConnectionId(Object root, Int32 connectionId, Object instance)
--- End of inner exception stack trace ---
at System.Windows.Markup.XamlReader.RewrapException(Exception e, IXamlLineInfo lineInfo, Uri baseUri)
at System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri)
at System.Windows.Markup.WpfXamlLoader.LoadBaml(XamlReader xamlReader, Boolean skipJournaledProperties, Object rootObject, XamlAccessLevel accessLevel, Uri baseUri)
at System.Windows.Markup.XamlReader.LoadBaml(Stream stream, ParserContext parserContext, Object parent, Boolean closeStream)
at Autodesk.AutoCAD.ViewModel.DocumentSwitch.DocumentSwitchServices.CreateDocumentSwitchControl()
at Autodesk.AutoCAD.ViewModel.DocumentSwitch.DocumentSwitchServices.GetInstance()
at Autodesk.AutoCAD.ViewModel.DocumentSwitch.DocumentSwitchServices.PlaceDocumentSwitchControl()
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.2101.1 built by: NET47REL1LAST
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Acdbmgd
Assembly Version: 21.0.0.0
Win32 Version: 21.0.402.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcdbMgd.DLL
adui21
Assembly Version: 0.0.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/adui21.DLL
AdUiPalettes
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdUiPalettes.DLL
WindowsBase
Win32 Version: 4.7.2099.0 built by: NET47REL1LAST
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System
Win32 Version: 4.7.2093.0 built by: NET47REL1LAST
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
PresentationFramework
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
PresentationCore
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
mscorlib.resources
Win32 Version: 4.7.2046.0 built by: NET47REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_tr_b77a5c561934e089/mscorlib.resources.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
AdApplicationFrame
Win32 Version: 2015.11.2.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdApplicationFrame.DLL
AdWindows
Assembly Version: 2016.5.0.0
Win32 Version: 2016.5.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdWindows.DLL
WindowsFormsIntegration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
PresentationFramework.Aero2
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero2/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero2.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
accoremgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/accoremgd.DLL
Acmgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/Acmgd.DLL
AcWindows
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcWindows.DLL
AcWindows.resources
Win32 Version: 21.0.52.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcWindows.resources.DLL
AcCui
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcCui.DLL
PresentationFramework-SystemXml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
System.Windows.Forms
Win32 Version: 4.7.2094.0 built by: NET47REL1LAST
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
PresentationUI
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll
System.Xml.Linq
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
PresentationFramework-SystemXmlLinq
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
AcSeamless
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcSeamless.DLL
Microsoft.GeneratedCode
Assembly Version: 1.0.0.0
AcSeamless.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcSeamless.resources.DLL
BIM360GlueAutoCAD2017Addin
Assembly Version: 4.37.6853.0
Win32 Version: 4.37.6853.0
CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/AutoCAD2017Addin.bundle/Contents/Win64/BIM360GlueAutoCAD2017Addin.dll
BIM360GlueAddinsCommon
CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/AutoCAD2017Addin.bundle/Contents/Win64/BIM360GlueAddinsCommon.DLL
log4net
Assembly Version: 1.2.11.0
Win32 Version: 1.2.11.0
CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/AutoCAD2017Addin.bundle/Contents/Win64/log4net.DLL
FeaturedAppsPlugin
Win32 Version: 21.0.46.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Autodesk/ApplicationPlugins/Autodesk%20FeaturedApps.bundle/Contents/Windows/2017/Win64/FeaturedAppsPlugin.dll
PresentationFramework-SystemCore
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll
Anonymously Hosted DynamicMethods Assembly
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
UIAutomationTypes
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
ContextualTabSelectorRules
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcWindows.dll
Microsoft.Expression.Interactions
Win32 Version: 2.0.20520.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/Microsoft.Expression.Interactions.DLL
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
0 Me gusta
Responder
3.245 Vistas
4 Respuestas
Respuestas (4)
pendean
Community Legend
Community Legend
0 Me gusta
No aplicable
i dont know which one i should download . I had Autocad 17 i uninstall and i download autocad 18 . 18 is perfectly working. I dont understand the problem in Autocad 17.
0 Me gusta
pendean
Community Legend
Community Legend
IF 2018 works well stick with in: or do you exchange files with others so often that might be a pain to save down constantly?
0 Me gusta
No aplicable
I uninstall Acad 17 and now all of my files open with Acad 18 . There is no problem for now. I didnt do anything spesific for exchange. if i have to can you please explain to me ?? and thank you so much for your care.
0 Me gusta
