api-ms-win-crt-runtime-l1-1-0.dll error in AutoCAD 2017
Message 1 of 29
Can anyone help me solve this error. I Installed AutoCAD 2017 on my laptop which is running Windows 7 Professional. Upon launching i encountered this error - api-ms-win-crt-runtime-l1-1-0.dll is missing from your computer. I tried a solution from what I have read from other sites like Windows update etc. but it did not work. Any help will be appreciated.
thanks,
Dennis
Replies (28)
Message 21 of 29
i too having the same problem in my windows 8 but the eeror its showing is api-ms-crt-string-l1-1-0.dll is missing from your computer try reinstalling the programme... plz help me with this.
Message 22 of 29
Alfred.NESWADBA
So use the same solution in that thread ... post 9 is marked as solution, take it 😉
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 23 of 29
hi,
i saw that earlier only and followed those steps too but it didnt work
any other solution for it?
Message 24 of 29
Alfred.NESWADBA
There are a lot of suggestions >>>click<<<, most of them get solved by uninstalling and reinstalling the VC++Redist's, but maybe you find more within the search results.
Good luck, - alfred -
Alfred NESWADBA
Message 25 of 29
thank you so much.. i will definatelty try out these....and will get back to you soon.
Message 26 of 29
What a surprise it does not work. I have another PC that has autocad 2017, is it possible to find the file and copy it? Where would it be located if this is possible?
Thanks.
Message 27 of 29
Alfred.NESWADBA
You might copy it, but it has to install some components with it.
Running the re-installation of the VC++ redist's will add the file, it's components and it's registering.
I recommend to go through all versions of VC++ as described >>>there<<<.
- alfred -
Alfred NESWADBA
Message 28 of 29
Hi everyone, I'm new here and need help.
I'm having the same problem as well when trying to install SketchUp. Does the solution given also apply to SketchUp application?
Message 29 of 29
For more details about this you can visit ths page or read this article, click here
