Any option to show more information while drawing a polyline?
timLNMHN
timLNMHN
As you can see in the picture I get the length and angle of the polyline I am drawing. Though is there an option to enable so that I can also see how far away I am from the polyline to the greyline as seen in the picture.
i think I have seen it before but I don't know if it is standard to Autocad.
Thanks in advance 🙂
tramber
No it is not !
But, whenever you want, you can entrer 'DI (don't forget the ') to get information between two points.
'DI or 'DIST must work.
And remember : whenever you want as long as you don't forget the '
It's called a transparent command.
