annotative text
annotative text
Darwin33
Message 1 of 16
annotative text
Darwin33
I wonder if it is possible to do that in autocad. In an architectural work enviorment is often usefull to draw text in model espace of 0.2m high bcz of the scales I think that that measure is comfortable to work. But in paper space I would like that no matter the scale of the windows that text will have 2mm high to plot. Is there any way to do that, bcz I understand that what you can do is to fix your text in model space like annotative and then in paper space will always keep the high you chose on model space. Thank you
Replies (15)
Message 2 of 16
pendean
Community Legend
Community Legend
Annotative Text, dimstyles, mleaders, leaders, blocks and more have ben around for quite some time in AutoCAD and it's variants and your layouts/viewports do NOT need to mimic or duplicate any annotative scale in your model tab.
What exactly is the challenge you are facing? I suggest you simply try it otherwise, I think you might have read something wrong somewhere. The experience is what you want if I understood it correctly (and you do too).
Message 3 of 16
imadHabash
your understand is correct @Darwin33 when you wrote (... bcz I understand that what you can do is to fix your text in model space like annotative and then in paper space will always keep the high you chose on model space.)
all what you have to do is a adding annotative scale for your text then every thing will be fixed in viewports .
Good Luck...
Imad Habash
Message 4 of 16
Darwin33
Almost, what I specifically need is to have same size in model space i.e. 0.2 (model space units) and same size in paper space I.e 2mm, regardless the scale of the viewport. Note I need same size in all viewports in paper space, but different in model space.
Message 5 of 16
RobDraw
Yup, annotative scaling will do exactly what you are asking and has been available for some time now.
Rob
Message 6 of 16
john.vellek
Hi @Darwin33,
Try setting up a new annotative text style to see how it works!
John Vellek
Message 7 of 16
pendean
Community Legend
Community Legend
Show us your DWG file please. We'd all solve this for you in a minute.
Message 8 of 16
RobDraw
Most of us are getting what he is putting down. This is more a matter of best practices and getting to know about annotative scaling than about what to do in a particular file.
Rob
Message 9 of 16
pendean
Community Legend
Community Legend
Nothing like presenting a user with a solution in their own file for them to get the best fix for their exact need IMHO.
We all are still throwing generalities at the OP and they are slowly struggling with it: good learning curve if they don't lose interest.
Message 10 of 16
RobDraw
"Give a man a fish and he eats for a day. Teach him to fish and you feed him for a lifetime."
Annotative scaling was a tough nut for me to crack until I "got it". Then it wasn't that difficult.
Rob
Message 11 of 16
pendean
Community Legend
Community Legend
🙂 It's easier to "get" in your own files with your own content too 🙂
Message 12 of 16
john.vellek
HI @Darwin33,
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
Message 13 of 16
RobDraw
We are on different sides of the fence on this one. When I'm learning something new, I don't retain much from a walkthrough that works on a particular file. I think people learn more, faster when given the tools and then have to figure out how to apply them and fix things when they misapply them.
Rob
Message 14 of 16
Darwin33
Thank you all
After one afternoon+evening strugling, finally I managed to work  with annotative scales. The key is to understand that you need first to fit a scale between the model space and a teorical viewport ie if you are moodeling in meters and you want to plot in mm, then if you draw a  text in model space with 0,2m, then fix an annotative scale of 1:100, so you will plot that text in a paper space like 2mm high.After that you have two options, either select in the bar below the option automatically create an annotative scales on new viewports, (what increase the size of your file) or create yourself a new annotative scale on every viewport.
Summarizing I found this order very usefull and great help to organize the use of text in viewports.
Thank you all for your help
Message 15 of 16
RobDraw
But wait, there's more. It works for blocks and dimensions, too.
Rob
Message 16 of 16
john.vellek
Hi @Darwin33,
I am glad that you made the "jump" 🙂
Can you please take a moment to mark as Accepted Solutions the post or posts that helped you with this question?
Accepted Solutions make it easier for other community members to find answers too!
John Vellek
