Annotative Scale/Viewport Scale/Plotting
manuremanager1
manuremanager1
Hi I can't change my viewport scale to a standard scale, using the properties or toolbar.  I believe the annotative scale is not letting me do it...  A new problem on a new installation I have.
My viewport is NOT locked!  Help!
pendean
Community Legend
Community Legend
Create a new viewport: still have the problem? If not, replace the old one with this.
Otherwise... Show us your DWG file with this trouble-some viewport, and point to it.
john.vellek
Hi @manuremanager1
Can you create a new layout and a new viewport on it? If so, see if you can adjust the scale factor there.
Can you attach your drawing for me to see? I am guessing that your viewport might be on a locked layer or that it is corrupt.
John Vellek
imadHabash
Hi and Welcome to AutoDesk Forum,
just to remind not more.... you have to click inside the viewport when changing the scale.
Imad Habash
john.vellek
HI @manuremanager1,
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
