I created an annotative dimension in modelspace on a layout tab. The text is very small. The viewport scale is 3/16"=1'0". When I look at the dimension properties, the annotative scale is 1:1 and I cannot change it. The select box allows me to create new scales and I can even select one, but it does not 'take' and reverts back to 1:1.
I have other dimensions that are annotative with an annotative scale of 3/16"=1'0" on my drawing that work perfect. What would be stopping me from changing the annotative scale on new dimensions?
The crazy thing is that when I select the dimension, it is highlighted blue and the text size is correct. When I select off it, the text size shrinks to nothing.
And it looks like it is correct in the modelspace tab.
What am I missing?
Thanks.
