I have annotative objects in one of my drawings. Each object can only be "assigned" one scale. In my case, the scale I am using is 1" = 30'. My main viewport is also set to 1" = 30' and the annotative objects show up the right size when viewed on a layout. However, there are times when we need to do callouts and dimensions, and the spacing is too small to accommodate them. In these instances, we do a blowup by creating another viewport on the same sheet, set to 1" = 10' or 1" = 20', of a small section of the drawing. However, the size of the annotative object always shows up bigger in that blowup viewport and is not uniform with the same annotative objects in the main 1" = 30' viewport.
Is there a way to set up the drawing such that annotative objects show up the same size in paper space despite being in two or more viewports of different scales?
