Annotative multileader will not come in with annotative text
No aplicable
I have everthing set to annotative - text style, dimensions and multileaders, however when I use the multileader on a drawing, the text style is too large and keeps reverting back to "standard" not annotative.  When I use multi-text, everthing is correct - stays annotative.  Also, all my dimensions sizes are staying annotative.  Is there a setting I am missing?
0 Me gusta
Responder
Soluciones aceptadas (1)
1.739 Vistas
2 Respuestas
Respuestas (2)
Jay_B
Solución aceptada
Can you share a dwg file here with this issue?
What version & service pack of Autocad?
What is MLEADERSCALE set to?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
No aplicable
Hi Jay, Thank you for replying. I am a new user to the annotative system and have just jumped from AutoCAD Lt 2011 to AutoCAD Lt 2016, service pack 1. I did finally solve my issue when I finally found MLEADERSCALE through Annotation on the Ribbon Bar. For some reason the default was set to 4 while all other annotative text was set to 3. I thought annotative text style comes in correctly when working in the model space viewport accessed from paper space, with the scale of the viewport set? In addition, every time I set the multi-leader style to annotative, it would pop back to Standard. However, I was setting this up initially from one of the other toolbars menu. It seems that different options are available depending on which way you access the information. In any case, it is all working appropriately now. Jacqueline
0 Me gusta
