Annotative dimensions multiply by 2
Darwin33
Darwin33
I am experimenting an issue
I have configurated my dimensions as annotatives, but the problem is that when I dimension on PS the value of the dimensions is multiply by 2, in any viewport.
Thank you for the help
john.vellek
Hi @Darwin33,
This definitely sounds like something is not set up correctly. Is it possible to share a file that demonstrates the issue?  Obviously Annotative Dimensions should always reflect the measured value.
John Vellek
chriscowgill7373
Drawing would be helpful, sounds like your dimension style has a 2x multiplier in it.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
Darwin33
Finally I found out the solution of my issue. as I usually dimension in paper space I found that I havent the system variable DIMASSOC with 2 selected, so if you dont have DiMASSOC 2, the dimension in paper space linked to your real model doesnt work properly.
Thank you all
GrantsPirate
John V posted a solution to this in May.
https://forums.autodesk.com/t5/autocad-forum/annotation-scaling-in-paperspace/td-p/7084695
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
