Very curious behavior of these Rotated Dimensions (why not simple linear dimension with aligned text?). I first noticed the Fit condition for "172" vs "177" in "H1" vs "j1" and I was going to point out the text size driving the placement. No big deal for that condition.
I then noticed the dimension text size across the vertical dimensions to the right of the first and I see what you mean.
I used properties to see if there are any varying settings between the one shown properly and the one's shown too small but all of the settings appear the same except for the Precision under the Primary Units section in Properties.
I looked at your list of Dimension Styles and I notice something that I always caution students about... Overrides. You can observe the differences in the Overrides by selecting Compare in the Dimension Style Manager (I didn't see any size or precision differences). I make your "NC-DIMENSION" style current and the overrides go away (as is normal). This does not correct your problem but it is a condition that I avoid. I usually prefer to Modify my dimension styles if changes are needed or create new styles as required. Overrides can get messy and you may have used Overrides multiple times while detailing your drawing.
I strongly suspect Overrides may have led to your appearance problem.
To correct your appearance problem en masse I would simply recommend dumping the overrides and using Update on the Dimensions panel, toolbar, or menu. Update will prompt you to select objects and you can type All or you can use a window around the entire H1 or j1 view. This made all appearances look proper but not sure if this makes any undesired changes.
I did notice that some of the values pick up a decimal to their measurement which is not shown when they appear small. If you want a precision with no decimal places you should Modify the dimension style, not override. If you want to remove decimals precision for only certain views or details then I'd recommend just creating a new dimension style off of the first with only the precision setting different. You can then window around an entire view and select the new dimension style to apply to all dims in your selection.
Hope all this isn't too confusing? It took me a bit to sort this one out;)
If a screen cast would help let me know.
Cheers,
Blaine
Blaine Young
Senior Engineering Technician, US Army
