Annotative blocks not working
Message 1 of 13
Hi there, I have a fully annotative tool palette that i used in the Autocad 2018 for 2D drawings and my computer was recently upgraded so i got a new Autocad 2018 installed where i added the toolpalette as usual. However since the Autocad was reinstalled i cannot seem to see the blocks properly. Some of them are working and I can see them and others i can only see some entities of them like an arrow without text or titles where i can see the scale but not the title etc. can someone please assist me with fixing this im not sure how, Its happening on other peoples computers who have had it reinstalled as well. The dimensions are leaders are fine its the special blocks that are a problem.Capture.PNG
Replies (12)
Message 2 of 13
Joe.Gio
Have you tried playing with your annotation options in the bottom right hand corner? They may be turned off etc.
Message 3 of 13
hi there it is on for some reason if i select the block and move it like 1mm away it pops up again and views fine but as soon as I press save and close the drawings when i reopen it the blocks are not viewing properly againbefore movingbefore movingafter movingafter moving
Message 4 of 13
imadHabash
would you please SAVE AS a drawing sample as AutoCAD 2013 type format and attache it here for testing ?
Imad Habash
Message 5 of 13
Hi sample atached ,
thanks
Message 6 of 13
imadHabash
in your Layout , every thing is appeared and nothing disappeared .
in your Model layout , i notice that you have some objects flying in the space !!! i think that your issue will resolve if you change your ANNOALLVISIBLE = 1 .
Command: ANNOALLVISIBLE
Enter new value for ANNOALLVISIBLE <0>: 1
Imad Habash
Message 7 of 13
it worked thanks so much
Message 8 of 13
no I lie lol it was already on 1 but when i put the command in again it worked but as soon as i pressed save and closed the drawing and reopened it i had the same issue and the command wouldnt switch it
Message 9 of 13
imadHabash
please when you close your drawing and open it again .... ANNOALLVISIBLE is set to  0  or   1  ? and if you toggling between those values any changes ?
Imad Habash
Message 10 of 13
i have done all of this it still stays as is it will only reappear if i move each entitle which i dont always have the time for
Message 11 of 13
imadHabash
Ok ... i just want one text sample that make this issue and attache it here if you don't mind ?
Imad Habash
Message 12 of 13
As soon as i move a text to a new clean fresh drawing it works fine but if i move the entire drawing the error persists im sure its a viewing problem and theres just a bug in the file are there any additional cleaning commands you perhaps know besides purge, audit, overkill etc.
Message 13 of 13
imadHabash
try  -Purge ( Regapps option ) and SCALELISTEDIT ( Reset ) .
Hope it's help ..
Imad Habash
