Annotative Block
Annotative Block
defiore.paul
Annotative Block
defiore.paul
hi.  is there a simple way to make a block annotative?  I have a block that won't allow the option to click "yes" to make annotative.  the block is a series of circles I want to scale down using the center as the scaling location.  using C3D 2015.  thanks
chriscowgill7373
would it be possible to share the block?  there are instances where certain properties prevent the block from being made annotative, one of these could be preventing your option.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
defiore.paul
so, I'm not able to share the block.  are there some properties of the block I can easily try changing that can make it annotative?
chriscowgill7373
I cant get one to reproduce what you are describing here on the fly, and I cant remember what I've done in the past that does something similar.  If I create a new block of a bunch of circles, I dont have an issue changing the property.  Perhaps if the block is already inserted, or there is an instance of the block that is not scaled uniformly.
Have you tried inserting the block in a brand new blank drawing and see if block editing allows you to modify the block then?
Oh_Snap!
Are you using the block editor (bedit command)?  when in the editor with nothing selected change annotative  to yes on the properties palette
tcubittDN9Z4
Community Visitor
Community Visitor
YES! This was exactly what I needed. Thank you
