Annotations Popped Up Out of no where?!? Why?
No aplicable
This is an elevator bank that would usually just have the elevator number, when pasting this drawing onto another these annotations I have never seen before came up? I am curious as to why this happened and how to make sure it doesn't happen again?
Thanks!!
0 Me gusta
Responder
331 Vistas
4 Respuestas
Respuestas (4)
wispoxy
Turn annotations off the tags. I'm guessing those are tag by the '_' underscore.
0 Me gusta
No aplicable
Thanks!!
Curious if these are Attributes?  Have you messed with ATTMODE yet?
0 Me gusta
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I am curious if the block definitions for your tags are slightly different from drawing to drawing. Can you attach a couple drawings so I can take a look?
You might also try using BATTMAN to take a look at the attributes to see if they are visible in one drawing and not the other.
John Vellek
0 Me gusta
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please attach a drawing if you want me to investigate this issue for you.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
0 Me gusta
