Angular Dimension not showing numbers
taylorv2015
taylorv2015
For some reason, my linear dimensions are showing but I'm having trouble figuring out why the angle isn't showing.
imadHabash
You may need to let the angular dim follow the dimension style settings.
Would you attache here the CAD dwg file itself for testing please?
Imad Habash
taylorv2015
Ok
imadHabash
Thanks for the file..
As i expect in my previous post.. You have to change the dim style for the angular dim to be as the same for other ones. Click on below image
Imad Habash
taylorv2015
taylorv2015
Hey, thanks for your response! I went in to properties and changed the dimstyle of the angular dimension to standard since the linear dimensions were standard now it's fixed.
