AutoCAD Forum
Anchoring lines to an object
5 REPLIES 5
880 Views, 5 Replies
Hello, I'm fairly new to autocad, and I'm currently laying out wiring diagrams in 2D using Autocad 2015.
Is there a way anchor a line to a box at both ends so that if you move one of the boxs the line moves with it while the other end stays in place?
I've searched around, but couldn't really find any answers.
Thanks!
5 REPLIES 5
steve216586
Stretch?
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
doben
Constraints - see the Parametrics tab on the Ribbon.
in reply to: steve216586
Well, I want to have, say 8 lines going into one box, then move that box and have the lines come with it while the other ends stay in place.
GrantsPirate
You need to post an example drawing so we know exactly what you are asking.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
kasperwuyts
You need to look into this command.  You should definitely try learning more about parametric drawing. it will open a whole new world of possibilites (and accompanying frustrations, of course).
Best regards
Kasper Wuyts
_______________________________________________________________________________
If this post solves your problem, clicking the 'accept as solution' button would be greatly appreciated.
”Boost
