Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
I have a file 'ProjectTable.dwg'.
It contains:
-some lines forming table
-name of company - CONSTANT
-name of drawing - Field with substr and getvar of DWGNAME
-number of revision - Field with substr and getvar of DWGNAME, other marks
etc.
I have also at the top of the table rows representing number, description and date of revision.
And all above is my XREF. Its not a drawing.
In every my drawing i attach this ProjectTable.
Name of every drawing is formated this way:
XXXX_YY_NNN... .dwg
XXXX - number of drawing
YY - number of revision
NNN... - name of drawing
So if my ProjectTable(xref) contains well formated Fields these variables work just fine in drawings.
My problem is:
I would like to achieve fitted number of rows to number of revision.
Revision0 - 1 row.
Revision1 - 2 rows.
Revision2 - 3 rows. etc.
And it should be automated from XREF / ProjectTable.dwg level.
I tried array of elements but DWGNAME or part of it cant be variable in Quick Calc.
Ive tried visibility but i dont have any idea how to connect it with 'YY'.
Is it possible to achieve moving rows and text in Drawing from Level of Xref?
Help me please.
I have this as variable
$(substr,$(getvar, DWGNAME), 6, 2)
Now i need to put it somewhere to do dynamic block or just start hidding and appearing lines.
I attach screen with the concept.
I could do only one Table with 10 revisions rows but it isnt a solution and in most cases it would take to much space.
I apreciate any help and hints.
Igor
I want to achieve idea attached on the image.
Idea explained in more graphic way. I can use whatever: points of line, atributtes. But not Lisp routine.
I doubt this magic is possible but let me know. Im not so advanced in this topic.
