altyernate measurements-settings
estimating7GS5A
Observer
estimating7GS5A
Observer
Observer
I was trying to set primary unit as decimal (metric- meter) and alternate unit as architectural(feet-inch). I tried many times through modify dimension style, out put values (alternative-architectural) are not matching. Could you please advise how to create decimal and architectural measurements to match?
0 Me gusta
Responder
297 Vistas
4 Respuestas
Respuestas (4)
pendean
Community Legend
Community Legend
Show us your DWG file with your attempts so far: we can walk you through what you may have missed etc. in your own file and you'll learn more and better that way.
0 Me gusta
GrantsPirate
What do you mean when you say you want metric and architectural units to match?  Give a quick example of what you are expecting to see when dimensioning.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
0 Me gusta
john.vellek
Hi @estimating7GS5A, Without more detail I am guessing that you can set your drawing units  in metric using UNITS. The, when you are using dimensions you can configure alternate units such as Architectural and put in the conversion factor.
If you are asking for something different please give me more detail.
John Vellek
0 Me gusta
john.vellek
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
0 Me gusta
