All text shifting after drawing saved and re-opened...
I'm running into an issue with my single line and multi-line text shifting ever so slightly either the left or right.This only occurs when I go back to the drawing after I've finished drafting and have saved and closed the drawing. Oddly enough, once I select the entity, select one of the nodes/anchors/handles, it jumps back into place. I wouldn't have too big of an issue with this problem, however if I do not go through the process of selecting and selecting a node/anchor/handle, the text will stay as shown in plotting. I'm using a client supplied .shx file and i'm wondering if that could be the issue. For clarity purposes, all text is affected, even those in blocks.
I've attached a couple PDFs to show how minor the shift is. The file "Upon opening" is after I've saved and close and then come back to it. You'll notice the qoutations of the text is overlapping a line. The file "Handle Selected" is exactly what it is. I select the text and then select the center handle and you'll see that the text shifts itself with my cursor not yet having moved. Sometimes it's to the left. Sometimes it's to the right. I've experimented with justification settings only for it to happen with every justification.
Does anyone have any ideas as to why this is happening? I wouldn't mind working around it but when my drawings consist of several hundred annotations, it can be very frustrating, especially when dealing with limited space in the drawing.
Any feedback is appreciated.
Thank you,
Duy
