All layout views move when I move one layout view
PBESSmgr
PBESSmgr
In AutoCAD 2016, this drawing has two Xref dwgs, one is clipped, and five layout views each with one rectangular viewport in the border. a different VPORT layer in layout 3. I want to reposition the view in layout 3. I dbl clk in viewport, click Move, select all crossing within the viewport, enter, click on base point, drag the view up afew inches, then click to paperspace. Then I check the layouts 1 & 2 and see that these have also moved. Why? Is this because of the xrefs or clip? Can it be changed?
0 Me gusta
Responder
Soluciones aceptadas (4)
2.951 Vistas
4 Respuestas
Respuestas (4)
jeff_rivers
Solución aceptada
If I understand right, you are in a paperspace viewport, and you then select all the entities in modelspace, move them, and then you see that they have also moved in the other viewports on your other layouts.
That's how it's supposed to work.  When you move the entities in modelspace, that will be reflected in every viewport.
If you want just that one viewport to show a different portion of the objects in modelspace, stay in paperspace on that layout, and use the grips to move the extents of that one viewport around.  Or use the <stretch> command to move the viewport extents.
Jeffrey Rivers
Win 10 Pro 64-bit, Intel i9 3.7GHz, 64 GB
NVIDIA RTX A4000
C3D 2020 V13.2.89.0
cadffm
Solución aceptada
@PBESSmgr  schrieb:
>Why?
Read below
No, nothing to do with xrefs or clips, just missing basic AutoCAD  knowledge for Layouts&Viewports
Then: DoubleClick into the Viewport and use command PAN (or Zoom and so on, commands to change the current view)
STOP! When you doubleclick inside a viewport, you are in MODELspace, if you change objects, for example the the position by MOVE command, cou change the objekts in your modelspace..
All Viewports are looking to the content of your modelspace and if you move an object, you will see it
in all viewports (when current view display this area)
You don't "drag a view" axcept you would use the PAN command.
You talk about to edit your model!
Sebastian
0 Me gusta
Alfred.NESWADBA
Solución aceptada
Compare viewports with Windows. If you look outside your window you see a tree as your model.
If you use _MOVE to move the tree to your neighbors garden and then you open your second window you'll see the tree has moved, it is not anymore in your garden. Just because you look through another window (viewport) does not mean that the tree has then not moved.
If you want a different view in the viewport, as already mentioned her, you need PAN (and ZOOM), but not _MOVE!
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
PBESSmgr
Solución aceptada
Doh! I had to unlock the scale! So much for my once a year AutoCAD use.
0 Me gusta
